kocaeli escort bursa escort eryaman escort istanbul escort antalya escort eskişehir escort beylikdüzü escort izmit escort bayan
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
Thread: Powder coating a shotgun barrel
  1. #1
    I have a customer asking about PC'ing a shotgun barrel. Aside from ensureing it does not get into or on the very end of the barrel, is there any reason this should not be done? It sounds like an 18" riot/home defense gun.
  2. #2
    Re: Powder coating a shotgun barrel
    I've done a few, other than masking being a little tedious, no problem.
    I wouldn't worry about powder getting in the end of a shot gun barrel, the shot will remove any over spray
  3. #3
    nomoreusmc
    Guest
    there are no problems with the powder although there are special gun ceramic coatings that look quite nice.
  4. #4
    Quote Originally Posted by nomoreusmc
    you mean, like this:
    NIC graphite black 870 police
    NIC coyote tan M4
  5. #5
    Fill me in on these gun ceramics! Do they spray and bake like normal powder or are they a high heat cure? Where can I look at them?
    And can I just media blas the outside and go, what about the factory blueing, and special prep on gun barrels because of blueing?
  6. #6
    nomoreusmc
    Guest
    Quote Originally Posted by Prostreet
    NIC coyote tan M4
    Yes exactly like that! That's what I was talking about from NIC, the have cool IR reflective technology in some of them too. Crazy stuff
  7. #7
    Quote Originally Posted by luv2fly
    Just to clarify, these coatings are liquid ceramic, not powder.
    [SIGPIC][/SIGPIC]
  8. #8
    yep, liquid coatings, pretty much like spraying automotive paint. very expensive though...
    direct to metal application, so all parts have to be sandblasted (blueing and all) with 120grit Al oxide. then you follow all manufacturer recommandations.
    yes you have to mask barrel ends but you can almost spray anything else as it goes very thin...
  9. #9
    Can powder go over blueing?
  10. #10
    I had a bad experience with the blueing messing up the powder.
    I didn't realize how penetrating the blueing was, make sure to blast very well
    similar to removing anodizing
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
