CJPC custom rim hangers
  • CJPC custom rim hangers
    Hey all, we just fabed these really cool rim hangers that makes it real easy to hang rims. Now it is a snap to get the rims in and out of the oven. Real strong, the rim has no sway at all and best of all they have handles so you can remove them when they are hot!!!! No burns!! YES!!! Check em' out!!
    Re: CJPC custom rim hangers
    How does that work? Do you put the rod through the center of the wheel and then attach the valve stem to that bottom hole using a bolt or something? If so, does that mean they are diameter specific?
      x3 can you show one attatched to a rim? im confused about how they hold the rim
        No Prob fellas. By the pic you should get the idea. I used a 1/4 20 3" bolt and some washers and a few nuts. The hole in the hanger is big enough to accomodate the bolt.
          Thank you now it makes sense !!
            x4
            I would like to see how the wheel fits on your hanger. If it looks good, I am sure that the orders will start coming in.
            http://i65.photobucket.com/albums/h2...89/NewLogo.jpg
              Yall must have been posting the pics the same time I was typing...lol.
                Looking good man, any close up shots of the valve stem area where the wheel is actually hanging? Thanks!
                  I have a question concerning hanging through the vavle stem hole. If yall are using a washer and a nut on the finished side of the wheel, then there is going to be an area not coated. Even if the valve stem covers this, wouldnt it still rust if its a steel wheel?
                    Well fortunatly all my rims have been aluminum alloy so far.....So I don't have the rust issue, yet. If I get a steel rim...I'll figure something out.
                      Here is your solution, use a bolt with a counter sunk head
                        Juan this picture is of the front of the valve stem area....zoomed in. All there is, is the 1/4 bolt with a washer going through to the back of the rim. Then the first pic I posted shows the rest of it. I hope this helps.
                          JH nailed it!!! That would work!
                            Thanks for the close-up man, that's what I had pictured but it helps to actually see it. Good idea, looks like it will work well.
                              Try to find acorn nuts-round side in the valve stem hole.
                              I could only find nylon lined lock type acorn nuts, so I burned the nylon out of them with a torch-
                              I think I am using 7/16" all -thread and acorn nuts. they fit right onto the hole snug, leaving no marks
                              not trying to hijack, rather build on this great idea. I think I want a set of these--
