Brembo calipers
  • Brembo calipers
    Pretty basic coat. SD red with a glass clear. They came out pretty nice
    Re: Brembo calipers
    they look good...
      Re: Brembo calipers
      Nice!
        Re: Brembo calipers
        I am in awe
          Re: Brembo calipers
          Why the clear over the SD? I thought the Super Durable tag was so you don't need a clear.
            Re: Brembo calipers
            Looks sweet.
              Re: Brembo calipers
              I put the clear on them for the higher gloss level. The SD red wasn't a wet powder so the gloss level seemed to be only about 60%, give or take a bit. The clear really made them shine.
                Re: Brembo calipers
                Thanks. Nice job!
                  Re: Brembo calipers
                  Just a note: The SD Fire Engine Red cures at as little as 320 degree's, the lower temperature you cure her out-the smoother the finish-which shows a higher gloss...
                    Re: Brembo calipers
                    thanks for that tip!!!
                      Re: Brembo calipers
                      No problem bro....anytime!
