There are a few ways of measuring the cured and uncured powder: Some are destructive some are Expensive, but over all the best is practice and patience while you learn.
Regardless of the method used, it is important to note that the thickness of powder coating may change during the curing process, so measurements should be taken after the coating has been fully cured.
https://www.powderbuythepound.com/po...ess-gauge.html
- X-Ray Fluorescence (XRF): A laboratory technique that uses X-rays to measure the elemental composition of a material, including the thickness of a coating. This method is non-contact, highly accurate, and non-destructive.
- Film Thickness Gauge: A handheld device that uses magnetic or electromagnetic induction to measure the thickness of uncured powder coating on a metal substrate. This method is non-contact, fast and accurate.
- Measuring Tape or Calipers: A simple measuring tape or set of calipers can be used to measure the thickness of uncured powder coating on a flat surface. This method is low-tech but provides accurate results.
- Powder Coating Thickness Standards: A set of metal plates with a known thickness of coating can be used as a reference for measuring the thickness of uncured or fully cured powder coating. This method is more accurate but requires the use of additional equipment.
- Microscopy: A microscope with a micrometer eyepiece can be used to measure the thickness of a fully cured powder coating by visually inspecting a cross-section of the coating. This method is less common but provides highly accurate results.
