To Mask or Not To Mask
  • To Mask or Not To Mask
    1. Silicone Plugs - These are small, conical plugs that come in a variety of sizes ranging from 1/16 inch to 1 inch in diameter.
    2. High-Temperature Masking Tape - This is a type of tape that can withstand high temperatures and is used to mask off areas that do not need to be coated. It comes in different widths ranging from 1/4 inch to 2 inches.
    3. Threaded Plugs - These are small plugs that screw into threaded holes and are commonly used to mask off holes on machine parts. They come in different sizes ranging from M4 to M20.
    4. Rubber Caps - These are caps that fit over the end of tubes or pipes to prevent powder coating from getting inside. They come in a variety of sizes ranging from 1/8 inch to 2 inches in diameter.
    5. Powder Coating Tape - This is a specially designed tape that can withstand high temperatures and is used to mask off areas that need to be coated. It comes in different widths ranging from 1/4 inch to 2 inches.
    6. Heat Shrink Tubing - This is a type of tubing that is placed over wires or cables to prevent them from being coated. It comes in different sizes ranging from 1/8 inch to 1 inch in diameter.
    7. Spring Plugs - These are plugs that are designed to expand when inserted into a hole and provide a secure fit. They come in different sizes ranging from 1/4 inch to 1 inch in diameter.
    8. Masking Discs - These are round discs that can be used to mask off specific areas that need to be coated. They come in different sizes ranging from 1/4 inch to 2 inches in diameter.
    9. Tapered Plugs - These are plugs that are designed to fit snugly into tapered holes. They come in different sizes ranging from 1/8 inch to 1 inch in diameter.
    10. Conformal Coating Masking Tape - This is a specially designed tape that is used to mask off conformal coating areas. It comes in different widths ranging from 1/4 inch to 2 inches.
