20 Killer Tips for The Best Outcome
  • 20 Killer Tips for The Best Outcome
    10 reasons why proper metal prep is so important for powdercoating:
    1. Adhesion: Proper metal preparation is essential for ensuring good adhesion between the powder coating and the metal substrate. Without proper preparation, the coating may not adhere well, leading to peeling, flaking, or chipping.
    2. Durability: Powder coating is known for its durability, but this is only possible if the metal substrate is properly prepared. Proper prep ensures that the coating will be able to withstand the stresses of use and the environment, resulting in a long-lasting finish.
    3. Appearance: Proper metal prep helps to ensure a smooth, even surface for the powder coating to adhere to, resulting in a more attractive finish.
    4. Corrosion Resistance: Metal prep removes any rust or corrosion from the metal substrate, creating a clean surface for the powder coating to bond to. This can help to prevent future rust or corrosion from developing.
    5. Surface Cleanliness: Proper metal prep ensures that the surface is free of any contaminants, such as oil, grease, or dirt, which could interfere with adhesion or affect the appearance of the finished product.
    6. Cost Savings: Proper metal prep can help to reduce the likelihood of coating failures, which can be costly to repair or replace. By investing in proper prep upfront, you can save money in the long run.
    7. Time Savings: Proper metal prep can also help to reduce the time needed to complete the coating process. If the surface is properly prepared, the coating can be applied more quickly and efficiently.
    8. Consistency: Proper metal prep helps to ensure consistency in the coating process, resulting in a uniform finish across all parts.
    9. Environmental Impact: Proper metal prep can also help to reduce the environmental impact of the coating process, as it can help to minimize waste and reduce the need for toxic chemicals.
    10. Customer Satisfaction: A properly coated part looks better and lasts longer, resulting in greater customer satisfaction.
    10 reasons why you must pre-heat the oven prior to putting your coated parts in:
    1. Curing: Pre-heating the oven helps to ensure that the powder coating cures properly, resulting in a hard, durable finish.
    2. Time Savings: Pre-heating the oven can also help to reduce the time needed for curing, as the parts will start to cure as soon as they enter the oven.
    3. Consistency: Pre-heating the oven helps to ensure that the curing process is consistent across all parts, resulting in a uniform finish.
    4. Adhesion: Pre-heating the oven can also help to improve adhesion between the powder coating and the metal substrate, as it helps to activate the curing agents in the coating.
    5. Reducing Defects: Pre-heating the oven can help to reduce the occurrence of defects, such as orange peel or outgassing, which can occur when the coating is not cured properly.
    6. Time Management: Pre-heating the oven can also help to manage production time more effectively, as the parts can be loaded into the oven as soon as they are coated, rather than having to wait for the oven to reach the desired temperature.
    7. Energy Savings: Pre-heating the oven can help to reduce energy consumption during the curing process, as the oven does not have to work as hard to bring the parts up to temperature.
    8. Safety: Pre-heating the oven can also help to improve safety by reducing the risk of flash fires or explosions that can occur when parts are exposed to high temperatures too quickly.
    9. Maximizing Oven Life: Pre-heating the oven can help to prolong the life of the oven, as it reduces the amount of stress on the heating elements and other components.
    10. Cost Savings: By ensuring that the powder coating cures properly, pre-heating
    Buy Powder Coating Paint at Powder Buy The Pound. Including RAL Colors, Candy Colors, Super Durable Colors, High Gloss Colors, Matte Colors and more. Shop for Nordson Powder Coating Gun Parts, Gema Gun Parts, and Wagner Gun Parts and other Powder Coating Equipment. Powder Buy The Pound offers Powder Coating Training and Hydrographics Training. We are based in the South, located right outside of Nashville Tennessee. We Ship Same Day for orders placed before 2pm Eastern.
