I had this frame blasted, and cleaned. But during all the times i have handled it I have left oil from hands on the part. Also the oil tank still had a smidget of oil that ran out and onto the frame. What is the best way to reclean this before coating it ?
Motorcycle frame prep?
Tags: None
Re: Motorcycle frame prep?
Originally posted by JHFormanI had this frame blasted, and cleaned. But during all the times i have handled it I have left oil from hands on the part. Also the oil tank still had a smidget of oil that ran out and onto the frame. What is the best way to reclean this before coating it ?
Quick easy clean i use is Brakleen... spray clean & dry with Air gun..
Originally posted by HarleydadAlso "if possible" I would remove the oil tank from the frame (if it isn't already) and pc it separately.
Cant be done its built into the frame(its a Yamaha YZF bike). only way to remove it is to cut the frame apart
Originally posted by JHFormanOriginally posted by HarleydadAlso "if possible" I would remove the oil tank from the frame (if it isn't already) and pc it separately.
Cant be done its built into the frame(its a Yamaha YZF bike). only way to remove it is to cut the frame apartjk
Originally posted by BeeBobMake sure and flush that oil tank out real good or you'll have a heavy smoker in the oven! I agree with the brake cleaner it works great and leaves no residue.
Make sure it is NOT the ABS safe stuff tho. It does leave a residue.
BTW, A YZF should be a wet sump. No external oil tank, the oil is held in the engine.
I ended up using about 4 cans of brake parts cleaner on it and the subframe, it came out like this:
Ya know, I worked at a Yamaha dealer for 12 years, you'd think I would have caught that. My bad, yes, you're of course right, the YZF (dirt bike) is a dry sump. I'm a street bike guy, so when I saw YZF, I was thinking YZF R6 or R1, streetbike, which is wet sump. The 4 stroke dirt bikes never even crossed my mind. Sorry for the confusion. Ignore me.
Originally posted by nitsujYa know, I worked at a Yamaha dealer for 12 years, you'd think I would have caught that. My bad, yes, you're of course right, the YZF (dirt bike) is a dry sump. I'm a street bike guy, so when I saw YZF, I was thinking YZF R6 or R1, streetbike, which is wet sump. The 4 stroke dirt bikes never even crossed my mind. Sorry for the confusion. Ignore me.I have been racing motorcross for 8 years and recently ventured to supermoto. Yamaha has some of the best bikes available
Supermoto is a bunch of fun. I do a lot of trackdays, and I've managed to get some seat time on various supermoto's. Tons of fun. I've been wanting to build one for a while, but this isn't going to be the year. I just bought a new bike, then lost my job, so another bike is out of the question for now.
