Fatboy wheel suggestions
  • Fatboy wheel suggestions
    Anyone have any suggestions on the best way to coat these fatboy wheels. They look good in the pic but the black actually looks like it was done with a paintbrush. I was just going to outgass, blast, and coat but thinking since they are aluminum that I might need to try KL primer due to outgassing issues.
    http://i65.photobucket.com/albums/h2...89/NewLogo.jpg
    Re: Fatboy wheel suggestions
    I bet they are forged and outgassing won't be nessecary.
      I agree - I don't think those are cast.
        +1. Outgassing shouldn't be an issue with those.
          No gas for that FatBoy
            Thanks for the info folks. I will try without outgassing them. I guess I will have to stay away from the mexican food so this fatboy can stay away from the gassing issues also...
              sorry guys but i think those are cast not forged , i have polished dozens of those , i coated 2 sets and had many of them machined down to remove the section where you see all those decorative holes .
              when polishing i had a few pinholes showing up in different places , of thev 4 that i coated only 1 showed a few outgasing signs but very little (like three little pin holes that you could actually see)
                Cast centers maybe?
                The rim part doesn't look like it would be cast to me, but the centers may.
                  I just did a cast solid wheel like that. The outside edges where machined smooth and the main inner body was left rough. I agree with Baz, I think the wheels are cast. I did have some minor OG'n ( in the rough cast area ) with the first coat, but after sanding smooth the second coat covered it.
                    Originally posted by Jay V
                    Cast centers maybe?
                    those wheels are i piece like beebob says the rim edge is machined and the center part is left as cast
                      OK, looks like I am wrong then...
                      I didn't expect they would be 1 piece judging from from the rivets.
                      Aren't most aftermarket disc wheels 3 pieces?
                        Well ya never SAID they were aftermarket until now!
                          look again no rivets on those wheels these ae just 1/4 deep blind holes all around the rim atop be a harley dealership and look on some fat boys and you will see .
                          but you are right the ones that have the rivets usually (centerline wheels ) are three pieces
                          the hub and a spun aluminium disc on each side , bead of silicone between the 2 halfs and then riveted all aroud the disc and bolted with 5 bolts around the hub piece the hub on those is cast aluminium
                            Thanks Baz,
                            I didn't realize they were holes not rivets - not much HD knowledge here...
                            Thanks for the info on the Centerlines - that's more of what I was thinking they were.
                            Also - Is there a better way to look at a photo that is embedded? It's listed as an attachment, but is there any way to enlarge it to full-screen to get a better look?
                              These are not aftermarket, they are HD fatboy wheels and I do believe that they are one piece. I was going to coat them last night but had a rush job come in so they will have to be done tonight.
