i have shot this piece 3 times and i'm getting too much orange peel. it is a steel piece . it's a dash panel for a harley. i have blasted it with aluminum oxide and sprayed it down with acetone . warmed it up a little and shot it with mirror black. would shooting KL PRIMER first help me out? of course customer is in a little hury!
HELP WITH THIS PIECE PLEASE!!!
Re: HELP WITH THIS PIECE PLEASE!!!
can't tell you the mil thickness king but the first time i sprayed it on the light side . the second time i went a little heavier and the third time i used a differant powder and tried hot flocking a second coat. all the same outcome. the piece is smooth to begin with. it looks like a stamped steel piece with the front rounded part welded on. funny thing is the rounded part comes out better than (but not perfect) than the flat sides. i know flat pieces are the worst and of course it has to be black but i'm not going to let this piece go out looking like this.
Harleydad, i have been using the pbtp mirror black but i have the ral 9005 jet black. do you think i would get better results with the 9005? customer just wants "gloss black". i use a ir gun and the pictures are kind of hard to take because it was inside at night.
Wow very nicely done !! and harleydad youre a genious!!
You gotta tell us what you did. I'm in the same boat right now with a big chunk of alluminum. The round tubing comes out excellent the flat square tube is orange peeled all to hell. First time large orange peel, second time small orange peel. I need this part perfect! Did you sand between coats or just scotch brite the finish?
