ugly rims
  • ugly rims
    So I had a guy drop off a set of rims that wants recoated. These are the rims, should I be worried about how bad of shape they are in? They will be well blasted but will the corosion have gone into the pour of the metal and could cause problems withbubbling the powder down the road?
    Re: ugly rims
    Looks like you have a lot of cleaning ahead of you...lol but not to worry all that much. Once you blast and take of most of the gunk. I would use a 400 wet sand paper on it to make sure you get down to all of the corrosion in the pores. Although it shouldn't be that deep. You just might have to spend a little more time than you like wet sanding it. But if you take the time, you should be able to get a clean and smooth substrate.
      Re: ugly rims
      Looks like fun Crimson. Look at the topic Wiseguyz did called wheels from hell if I remember right. There should be all kinds of info there to help you. I think after a good blasting they'll be in pretty good shape. Make sure to outgas them good.
        Re: ugly rims
        yeah that was my plan. I am sending them out to have them blasted by a local guy that does it.
          Re: ugly rims
          I would also highly recommend using the KL primer prior to shooting your topcoat. That stuff goes a long ways in minimizing the outgassing problems (but be sure to do that first) and smoothing out the nasties.
            Re: ugly rims
            and how thye look afer coating
              Re: ugly rims
              much better, nice job...
                Re: ugly rims
                Awwwwsome
                  Re: ugly rims
                  Fantastic results!!
                  I'll bet you wanted to go take a poo when they were finished eh? stress relief?
                  lol
                    Re: ugly rims
                    Another set of wheels resurrected. Nice job.
                      Re: ugly rims
                      Very nice!
                      What color/powder is that?
                        Re: ugly rims
                        It's Bangel silver from Tigar Drylac
                          Re: ugly rims
                          So it is..... I only got it from Tiger Drylec because i needed it next day and they were the only ones in Canada that could do it. That will be changing soon with the Canadian PBTP!!!
                            Re: ugly rims
                            Did you just blast and coat or was there sanding & primer involved?
                              Re: ugly rims
                              Which is this powder from PBTP, Mirror Silver Sparkle (single stage)
                              http://www.powderbuythepound.com/catalo ... cts_id=544
                              good looking wheels ! I like the PBTP silver sparkle, it's very user friendly.
