Coating a soldered radiator?
  • Coating a soldered radiator?
    Can a radiator with soldered joints take the heat of PC?
    He wants either a glass clear, (cures at 340), or a chrome/glass clear. I don't want to ruin a brand new radiator for this guy.
    Thanks!
    Re: Coating a soldered radiator?
    There are a lot of solders that melt in the 350 degree range and some that melt as low as 200 degrees. I melted the solder out of an older automobile gas tank awhile back. IMO it would be risky.
      If possible, I'd contact the manufacturer and try to find out what solder they use and what the melting temp is.
        Like Wise said, make contact with someone that does radiators, even a repair shop should be able to answer your question. But if you think about it, the radiator in a car hits some pretty high temps at times. I don't think you would get hurt, but I would cure at around 350 to be safe. I have a few old style radiators here. I may just stick one in the oven and see how it goes. But I have seen somewhere on Internet where PCing a radiator is offered. Maybe do a Google on it.
