I have a customer that wanted a set of my aluminum grilles pc'd in "Baby Pink" with a slight metallic sparkle/flake. PTBTP's "RAL 3015 LIGHT PINK" is the color that I showed her, and she loves it. So, I ordered a pound of the light pink, along with 1 oz of ILLUSION STARDUST SPARKLE SILVER PEARL flake additive.
I wanted to test shoot it on a scrap piece of aluminum to see what it looked like cured, as some powders have a slightly different look on the bare aluminum. I sprayed the pink, cured it, then removed the piece and shot the clear/metal flake mix. I had a hard time getting the clear to stick, so it went on a little thicker. I made sure to leave a small area uncoated for the ground clip, and I shot the second coat about 5 minutes after I pulled the piece out of the oven. After I cured the clear/metal flake the piece came out looking more like a "peachy" color, than the light pink color. So, I went back and shot another piece of scrap to see if I could get it looking better with a flat black base coat. The pink seemed to come out better with the flat black base coat. Is this normal for RAL colors? Is there a better way to apply a second coat with the hobby gun (cure times, cooling time, best grounding tech.)? Any help would be great, as I am definitely a novice (been powder coating for about 2 months now).
Equipment I am using:
EW Hobby Gun
Electric Kitchen Oven
Curing at 400* F
Thank you in advance!
JD
EW Hobby Gun
Curing at 400* F
JD
