hi everyone iam fairly new on here my question is can u powder wheels with 2 diffrent colours i.e front face of the wheel lets say white with the inserts and sides ofthe spokes black no1 will coat 2 tone jobs in scotland most people will have there wheels wet painted 2 tone.iam justwondering if anyone can help me with like what u would do and what kinds of tapes ect ill requre ?
silly question
Re: silly question
i dont have a pic its just in genral it will be getting dun mostly to sets of alloy wheels the bit i dnt understand is do i coat the wheel with the base colour bake it off mask upthe areas i would like kept the base colour then how do i preheat the wheel so the second colour wil stick without melting the tape to the 1st colour as i stated in previous topic before i dnt really have any knowledge about powder coating the basics thats about it lol thanks for all the help guys
Re: silly question
my email adress is [email protected] and iam using a gema optflex i have noknowledge atall what settings are ment to be set for like metallics ect any info onthis machine and diff settings i can program would be great
http://www.itwgema.org/contento/Link...id=230&mid=993
Re: silly question
the green high temp tape will not melt under normal curing temps .
i never used the optiflex but both guns i use the older model gema and the wagner give similar results
you will have to practice and try different settings to see what s best for you but a good starting point
would be to set both the kv and the miliamps at 60 for most jobs , very large flt areas you can raise to 80,
complex shape you lower the settings , second coats try 40 or 45 kv for a start.
with my gema i can do 6 coats with no problems.
for air adjustments you adjust to have a nice unform powdercloud with no puffing or spitting with just enough pressure push that powdercloud over the part , but you don t want the air pressure to blow the powder off the part .
do a few tests and tell us how it turned out
Re: silly question
the machine iam using is gema optistar type cg07 the settings i allwas use it on are set to
flat surface
50 , 4.0
00 , 00
0.1 , 0.3
i ment aswell see if the green tape is still on the wheel wen ive masked iand shot the second colour do i put the wheel in the oven and start to bake it with the tape still on will it not stick to the 1st colour of powder ?
