If i had a design that i wanted to use as a mask. How would i get it to stick to the part? Is there some kind of glue i could get thats like the sticky side of high temp masking tape? I would want to remove the mask before full cure and not have it leave any residue I have material that will withstand the heat Just need to get it to stick to the part like tape. Thanks
masking
Re: masking
Originally posted by halfbakedIf i had a design that i wanted to use as a mask. How would i get it to stick to the part? Is there some kind of glue i could get thats like the sticky side of high temp masking tape? I would want to remove the mask before full cure and not have it leave any residue I have material that will withstand the heat Just need to get it to stick to the part like tape. Thanks
Re: masking
wow...check out this toy
http://www.kobisonline.com/Roland-SV8-V ... p_12.html#
I had never heard of a vinyl cutter...that is SOOO cool. you could do some awesome stuff with that. So that sheet vinyl will hold up to the flowout temp eh? then i assume its garbage?
Re: masking
Re: masking
My thoughts are, how often it would actually be used. In my case, I've not had a call for any special designs. But then I haven't had a reason to advertise it.My question to you that have one, has it been worth the expense and effort to get one? I've thought about it a couple of times, just haven't made the move yet.
Re: masking
Originally posted by JTW37My thoughts are, how often it would actually be used. In my case, I've not had a call for any special designs. But then I haven't had a reason to advertise it.My question to you that have one, has it been worth the expense and effort to get one? I've thought about it a couple of times, just haven't made the move yet.
Save the investment for when you actually get a job in the door that requires the need for a "bigger this" or "fancy new that", then grow your business into the work you took on. It would be the rare occasion when I'd turn down work because I didn't have the tools to do it (short of an oven big enuff to coat an aircraft carrier).
This is a whole lot easier than doing it the other way where you make an upgrade, and then try to scrounge new work to pay for it.
You'd be surprised too, that once you do that first BNG (that's Bold New Graphics for you non-moto-x types), you'll be doing a bunch of them. Word gets around pretty quick when you've got the new toy on the block
Re: masking
Ive had bad luck with every kind of tape leaving small ridges on the oposing side of the powder edge i was trying to make. It drives me crazy, even MEK won't take it off. The only way to get rid of it is to clear it.
If you are gonna go that far you may as well invest in a CNC plasma cutter. then you can cut your designs and powder coat them (think lawn ornaments). At least that one would be worth your while and pay for itself much faster imho.
Re: masking
Re: masking
IMHO, it is well worth the $....here is just a couple of the things we have done and like Harley said it just takes a couple of seconds to make custom dots using a mic to get exactly the size (with or without overlap) that you need plus I use my scrap pieces for the dots so I dont have much waste.
The red color on the tank is lollypop red ........just happened to be using red vinyl also:
Re: masking
Originally posted by slowdriveOne thing I might add is by the time you pay a sign shop for several large size logo's/lettering for your buisness name on vehicles/signs/banners you could of paid for a cutter with that money so long term I belive it is a wise investment.
Re: masking
Hey, I'm sold. I guess when you know and consider all that you can do with it, it's a good investment. A CNC would be nice, but right now I'm just a piker. Looks like I may be getting my first Jap bike soon, so who knows, what that job will bring. I seem to be having a sizable influx of work lately.
