Gas Cap ??
  • Gas Cap ??
    Guy wants his Gas Cap & Ring Coated. I know i have to remove the rubber ring but is there anything else i need to remove inside that could melt.
    This is off a Honda 954RR. Never did one for a honda. Mine i took completely apart and there was no rubber anywere inside just under the key hole flap. (which melted)
    [attachment=0:1kt1mivf]gas cap 9542 [640x480].jpg[/attachment:1kt1mivf]
    [attachment=1:1kt1mivf]gas cap 954 [640x480].jpg[/attachment:1kt1mivf]
    Re: Gas Cap ??
    I have done a couple, some have plastic parts in the hinge (found out the hard way ), other than that, everything else I have found to be seen easily.
      Re: Gas Cap ??
      Thanks S.Werkz, once i get it in my hands on it will check further into.
        Re: Gas Cap ??
        All the lock guts under the flip-up cover should unscrew and remove from the backside. I remove the entire lock/tumbler/vent portion that you show with the gasket around it.
