Gorund problem
  • Gorund problem
    Since I have moved in my shop I have not been able to get a good ground. The outlets are grounded and I do have a caswell gun and I cant tell the diffrence between 9kv with EW and the Caswell on all settings The past few days I cant get corners at all, cant even hot flock em. The only thing I can think of is my ground. Can somebody give me some idea or maybe some tips on what the best way to ground. Man this has been driving me crazy.
    Re: Gorund problem
    you can buy a grounding rod or just a copper pipe will work...supposed to be 8 ft into the earth I believe to be up to code, then just run a wire in to wherever you want it. Water pipes are supposed to be good too, some argue that. Gas lines are a piss poor idea, some argue that too, I say let them, there is gas in there.
    I patched right into the ground cable in my breaker box as my shop is right next to it and just ran a wire up over my table that I wrap on the rack, then I put the ground from the gun onto the wire. Be sure that ground cable isn't flopping about if you are welding
      Re: Ground problem
      go to Lowe's, home depot get a 6 ft ground rod drill hole in floor, then beat the hell out of it.
      leave it out of your floor about 4-6 inches and hook a ground clamp up to it.
      also drill hole larger x2 than the rod and pour 1/2 gallon of water down the hole about 1x a month to keep good contact
        Re: Ground problem
        lol, posted while I was typing nolatodd
        also should be attached to your spray booth, powder gun, any fluidized constantly, and the a wire to run to your rack
          Re: Gorund problem
          Connect the ground clip from my gun to the ground rod? Ive always connected to the part if possible. Would this be the result of bad ground?
            Re: Gorund problem
            My ground wire goes from the electric boxes ground to my rack and I clean it off so that I get good contact down the rack through the hook then I hook the lead from the pc machine to that too. and like Streetwerkz was saying...ground out everything...ground is good
            everything but the tip of your gun that is!!
              Re: Gorund problem
              I live 3 miles from lowes and home depo. I think I'll pick a ground rod up, I have some copper wire and try it.
              thanks
                Re: Ground problem
                sorry, my brain werkz faster then my typers
                run ground wires from the rod directly to the equipment, and to your rack/parts
                  Re: Gorund problem
                  What temp did you try hot flocking? You dont need a groung when you do that.......If the powder didnt stick you might have something else wrong.
                    Re: Gorund problem
                    Ground rod and clamp is only $15 @ Lowes. You'll need a mini BFH or a post driver to make it easy. Mine took better part of the day to drive cause my mini sledge broke and had to use a 12#er. That sucker got real heavy real quick!!!
                      Re: Gorund problem
                      Driving a ground rod can be a real bear with small sledge, try using an electric impact we have been using this practice for years with great results.
                      Ray
                      Ray
                      ONLY BECAUSE OF THE BRAVE
                        Re: Gorund problem
                        I would grab a pipe, weld a cap on the end and make two handles. Pound it with a hammer. Just like a fence post driver. And or take an auger bit as long as ou can feasible get and drill out a smaller diameter hole.
                        I grounded to the ground bar in the electical box with great results. Its grounded by a 8' ground rod on the other side of the wall, so It cant hurt.
                          Re: Gorund problem
                          is THAT why your right arm is so much bigger than your left?
                            Re: Gorund problem
                            Nope - that's not why.
                              Re: Gorund problem
                              By the time I got set up in my booth it was about 200. Itried without the ground. Its galvanize and its a second coat at that.
                              I got a 10' ground rod and put it in first thing this morning. I got luky with that. The ground was wet and I pushed it in maybe 4' then used a 18oz framing hammer. The ground rod helped but thats not the problem. I just got home
