The KL Primer. I bought a pound a couple weeks ago to see what the fuss is about and this stuff is my new favorite.... I had a motorcycle pedal that it appeared the customer tried to grind the flaking chrome off witha hatchet and the primer made it super smooth. Thanks guys
My new best friend
Re: My new best friend
We have a new primer which is called red oxide and is a epoxy pipe coating FBE (Fusion Bonded Epoxy) http://www.powderbuythepound.com/cat...oducts_id=1883. Because of this products fast cure times at higher temperatures, this could greatly help or eliminate outgassing. We will be doing testing on this product, and are pretty certain through some other testing that this product will work to eliminate or reduce outgassing.
Originally posted by powderbuyWe have a new primer which is called red oxide and is a epoxy pipe coating FBE (Fusion Bonded Epoxy) http://www.powderbuythepound.com/cat...oducts_id=1883. Because of this products fast cure times at higher temperatures, this could greatly help or eliminate outgassing. We will be doing testing on this product, and are pretty certain through some other testing that this product will work to eliminate or reduce outgassing.
