Shooting Clear over Mirror Black
  • Shooting Clear over Mirror Black
    How do you guys normally go about this? Do you wet sand the mirror black first or do you shoot over the smooth coating?
    Will clear fill sanding marks in mirror black if you were to wet sand a part before shooting clear?
    Thanks in advance as always,
    Mike
    Re: Shooting Clear over Mirror Black
    That is sort of what I figured, but I thought I would ask, hummmm, what to do!
      Mike what kind of issue are you having?
        i usually just shoot over the base coat ... like hd said . unless there is a problem i dont not sand . less chances of getting a spec of dirt in there .
          The problem I had was my daughter decided to step on the powder hose for about a second and then step off, then I got an amazing poof of a shite load powder on a corner of the intake I was shooting.
          Looking for easy way to fix, wanted to shoot one more coat, not 2.
          I normally do the clear same as H-dad, and have never done it any other way, wanted to know if it would work or not.
          F-it, Ill just sand the crap out of it and put black back on it, then clear.
          Thanks all
            not to get off topic, but what's with the plastic intakes? can they be powdercoated?
              Welcome to the forum redlinecustomsms!
              Yes they can be coated. It's a hotflock process. GONGCHAUN has done many.
                Thanks all
                I'm old.....HD's way?
                You don't think the clear would smooth it and hide the spot?
                  Sanded her back down tonight. In the oven now "warming", and hell yes its a plasitic LS based intake, that is where the big problem came into play, if it was aluminum, Id of just blown it off and started over.
                  And the story is, yeah baby, they can be powdercoated!
                    You da man GONGCHAUN Great job!
