Removing silicone sealant
  • Removing silicone sealant
    Media blasting? Propane torch? I'm just throwing ideas out there...
    Re: Removing silicone sealant
    Permatex gasket remover is my bet.
      nail polish remover should turn it into goo that soap and water and maybe a green pad will take right off.
        laquer thinner.saturate a rag,let it set a while,laquer thinner reduces the ammount of grease needed [elbow] to remove rtv sealant.
          you could try a brass wire wheel for your drill to get the alot off it off
            Lacquer Thinner and the rag will work, try to keep any wipe up to a minimum and use clean rags / paper towels often. Silicone spreads and is not visible, then use a paint prep which should help get rid of it. I've had a couple of paint jobs ruined because of the fish eyes silicone creates. Does PBTP have an additive for powder similar to Fish eye remover for paint? Good Luck!
            Ray
            ONLY BECAUSE OF THE BRAVE
              What is it? Paint stripper a lot of times will remove some silicone sealers. I have had this work for me when stripping cars for body work and painting.
                I have used acetone and it usually works pretty well.... You could also try stuff called goof-off. I think thats supposed to work, I think it even says on the can it will work....
                  I use this guy alot, I like to use a few Chemicals as possible
                  I got mine from Snap-on, I'm sure someone makes a cheaper version
                  Called the CRUD THUG
                    Is that a rotary needle scaler?
                      That thing does look seriously impolite!
                        yes it's fun
                          Nasty - I want one!
