Looking for the best glossy white for wheels...
  • Looking for the best glossy white for wheels...
    Ok, so I am going to be coating a set of wheels white. I am looking for the most durable finish and I want it to be a nice glossy very white, white haha. I was looking at the SD Wet White and the Epoxy White Snow Flake. Would a Clear be a good idea over either one of these? (I noticed mirror clear doesn't bond to the SD White, but I have acrylic and SD Crystal Clear) Do you think SD Crystal over SD Wet White would work? Or is that overkill? I was also planning a base coat of KL. Thanks in advance!
    Re: Looking for the best glossy white for wheels...
    Agreed
      Ok, thanks guys (and gal). I think I'm gonna stick with the Mirror white, since I already have it and it sounds like it's the whitest of the whites. I'll base coat with KL, then Mirror White, then the SD Crystal Clear. How does that sound?
        Personally I like the Glass Clear or Acrylic
          So do I, unless one would want the added durability of the SD Clear.
          Hmmmmm. I think I do want the extra durability. And I don't think it should make a WHOLE lot of difference from one clear with a white finish. Its going to be white and Glossy, they should all look fairly similar, right?
            You're call, one coat with SD Wet White or the Mirror White and a clear. I guess they would all look "fairly" similar. Although I'd be willing to bet that if you did each one with a different clear and lined them up you would see a difference.
            This is very true. But if I do it one way and like it... there's no way for me to like the other ones better since I haven't seen them
            Thanks for the input!
