Okay, got a guy needing a set of factory wheels coated black. They are on a toyota X-Runner I believe, would it be best to strip the original off or just coat over the factory coating? The wheels are currently silver. Thanks for any info.
Factory wheels
Re: Factory wheels
Save yourself some headaches and wanting to have someone kick you in the rump. Take it off (the coating that is there) and start from scratch. If it is paint, it won't like the heat and may peel off. If it's powder, you may have problems getting things to stick and it may bubble or loose it's stick and you will have to do it all over anyway. A blasted surface is better the what your thinking.
