Outgas?
  • Outgas?
    I have never done this style of frame before and not sure if i needed to outgas it before coating?
    Re: Outgas?
    i would as most of that frame is cast
    CHRIS
    Craved Coatings - Australia
      Re: Outgas?
      Cast parts are what need out gassing, though I see some parts of that frame that are cast. It certainly wouldnt hurt to og it. It seems to be more of a problem on older cast metals.
        Re: Outgas?
        If it is cast and you require a primer, check out the red oxide! That product is designed to crosslink with the topcoat and will not allow outgassing....works great on pot metal as well..
