Harley price check please
  • Harley price check please
    Harley springer front end 2 inch over stock(aftermarket),strip paint and blast, coat of kl primer and coat of sd wet black. The old paint won't be hard to get off it looks like some cheap satin black (maybe spray can). What's a fair price for this job? Thanks!
    Re: Harley price check please
    I'm not sure the difference in work I don't think much but I'm working on a KIWI frtend for an HD and I'm getting $200. Plus he threw in $50 if I take it apart. Hope this helps
      I don't think there would be that much difference in work, I was kinda thinking about $150.00 - $200.00, anybody else have any input? By the way thanks for the reply!!
        I did a stock harley springer front end for $225.00 in gloss black with no clear.
          same here, single stage in stock color
            I guess maybe I'll charge $225.00 then...that should be more than fair for kl primer and sd wet black.
            Thanks all!
              Damn I just qouted a guy a whole differnt price Im not even gonna mention it but it will be already apart and need to be blasted and coated in Gloss Black
                As long as you didn't screw yourself What kind of front end? Springer?
                  Yup, Springer.. I gave th eguy a qoute i thought was pretty good but i was about $60 short from your price...
                    That $200 and up range is not out of line. A springer frontend consists of about 10-12 separate parts.
                      how much would all yous charge just for the lower legs? i have a guy that wants the lower legs done on a wide glide. i have to sand down harleys clear coat, which i'm thinking is just regular paint, and sand off the corrosion. i've tryed beed blasting these and it make the top coat look horrible, so i'm thinking of just hand sanding them smooth, and shooting it with SD black. I was thinking $100.00, is that too steep?
                      "What doesn't kill you, only makes you stronger."
                      www.truebluepowdercoating.com
                      www.facebook.com/truebluepowdercoating
                        I would think $80 to $100 would be in the ballpark.
                          I charge $60.00
                            $75-$80. The coatings on those legs are powder not paint.
