OK I am going totally insane here. I have been having really bad luck with the siphon cabinet I picked up a while back so I decided to go get a canister system and use that in my cabinet. Nice idea, except I can't get this damn thing to work either. I have some black walnut shells I am trying to shoot and my compressor is supposed to push 9.9 cfm. I put the biggest nozzle on it and got some media out of it after playing with the little valve on the bottom forever and plugging it up a ton of times but it doesn't keep pressure with the big tip. If I put any other tip on it it plugs up immediately. I got a sack of playground sand (I know nasty I didn't want to waste my shells though) and got it to spray that ok with the big tip, then thought I had it down so I cleaned it all out and swapped back to the shells with no luck.
I wanted the black walnut because I do a lot of sheet metal and the guy at northern said that was the best for sheet, but it seems like the media is just huge...should I get something finer? Is that my issue? or am I possibly just sand blasting retarded?
