Cracking
  • Cracking
    Been having problems with cured powder cracking under bolt pressure.
    Usually try to do up bolts from behind where possible but sometimes have to pressure up to a threaded hole.
    Using flat washers but they sometimes crack it as well.
    Re: Cracking
    Most likely... I have an account that manufacturer's screw's and they use about 50 different colors...
      Re: Cracking
      To much pressure.[mabe] If you were using a screwdriver to tighten them they probably wouldnt crack. But it sounds like you might be using big wrenches and you can only go just so tight before the metal starts streatching and bending to meet the part its getting bolted to. Powder is pretty hard but it is softer than the two pieces of steel its getting squeezed between. Mabe try masking where your larger bolts and washers go that are requiring lots of torque.
      Send me a airline ticket and i will come help you figure it out
        Re: Cracking
        i agree with harleydad.undercured
