What are the do's and don'ts to top coating powder types different from the basecoat ? ie, poly's,hybrids,tgic,etc.
Mixing powder types?
Re: Mixing powder types?
Because I am a Blonde I am confused by your question but I will try to answer it to the best of my abilities. Powders are either for interior or exterior use, depending on the powder. This is due to exterior weatherability. You can top coat an interior product with a exterior product to allow for weatherabilty. If you are using two powder's that do not get along well...fully cure the base coat before applying your top coat.
Originally posted by THEKINGBecause I am a Blonde I am confused by your question but I will try to answer it to the best of my abilities. Powders are either for interior or exterior use, depending on the powder. This is due to exterior weatherability. You can top coat an interior product with a exterior product to allow for weatherabilty. If you are using two powder's that do not get along well...fully cure the base coat before applying your top coat.
It's the powders not getting along well... That I am referring to. I understand interior powders can be coated with a topcoat to protect them. Clears,candies,etc.
So as long as their fully cured you are good to go. Thanks
Here is what he is referring to....http://forum.eastwoodco.com/showthread. ... 822&page=2
I will chime in after a little bit.
Originally posted by THEKINGHarley, would you like Free copy of the powder coaters manual..just give me your email address and I will get it to you :P
Thanks,
Originally posted by Powder_Coating_ProsAwww....The Blondie is soo nice today.Originally posted by THEKINGHarley, would you like Free copy of the powder coaters manual..just give me your email address and I will get it to you :P
Originally posted by hjeadesOriginally posted by Powder_Coating_ProsAwww....The Blondie is soo nice today.Originally posted by THEKINGHarley, would you like Free copy of the powder coaters manual..just give me your email address and I will get it to you :P
Originally posted by hjeadesSounds good, thanks. I hope one day I will be able to return all the help that you and everyone here has givin me.
Originally posted by hjeadesOriginally posted by THEKINGHarley, would you like Free copy of the powder coaters manual..just give me your email address and I will get it to you :P
Thanks,
