Anyone got a link to some cheap 3300-3500 watt elements? Seems like most places don't list the wattage...
Oven elements
Tags: None
Re: Oven elements
This is what I used on my oven, you might be able to find them locally for cheaper like I did...
http://www.helpfulitem.com/product/WB44 ... 10002.aspx
http://midwestapplianceparts.com/stove- ... -4813.html
They are 3400 watters so they should work well for you
Re: Oven elements
Originally posted by [SMJuan]This is what I used on my oven, you might be able to find them locally for cheaper like I did...
You got 2 of them in your oven correct? Do you wish you had more? My oven will be 29 x 32 x 65 inside so I think thats a little smaller than yours.
Re: Oven elements
[quote=X-Link]Originally posted by [SM]Juan":1upyx2jm]This is what I used on my oven, you might be able to find them locally for cheaper like I did...
[url="http://www.helpfulitem.com/product/WB44K10002/GEOvenBroilElementWB44K10002.aspxhttp://www.helpfulitem.com/product/WB44 ... 10002.aspx[/url]
You got 2 of them in your oven correct? Do you wish you had more? My oven will be 29 x 32 x 65 inside so I think thats a little smaller than yours.[/quote:1upyx2jm]
I ended up paying just over 30 bucks, just a quick trip down the street. Yup, I got two of them in there. 72" H x 40" W x 33" D are my oven dimensions and they do a great job in there. I think 3 would have been perfect, but I'm crazy when it comes to being symmetrical so I would have ended up with 4 instead lol. It takes about 15-17 minutes to reach 400 and just about 20 minutes to get closer to 450. I think that's pretty good timing for the size. It climbs at a rate of about 1 degree per 2 seconds, this is usually in par with the smaller less dense parts inside. I hope that helps.
Re: Oven elements
What gauge sheet metal did you use inside?
Re: Oven elements
Originally posted by X-LinkWhat gauge sheet metal did you use inside?
I used 20 gauge in all inside walls except the door. That's 18 gauge. Then the outside is made up of 22-24 gauge sheet metal. All insulation is 4" mineral wool.
Re: Oven elements
[quote=[SM]Juan]Originally posted by "X-Link":2hzai6vkWhat gauge sheet metal did you use inside?
I used 20 gauge in all inside walls except the door. That's 18 gauge. Then the outside is made up of 22-24 gauge sheet metal. All insulation is 4" mineral wool.[/quote:2hzai6vk]
Thanks!
Re: Oven elements
I used the same ones that juan did,i got mine from this place http://cgi.ebay.com/Replacement-for-GE- ... m153.l1262
I did find them locally,but they wanted a arm and leg
scott
Re: Oven elements
Ok so I removed the elements from my old kitchen oven and the regular element is 3000 watts and the broiler is 2900 watts. So 5900 watts total
You think that will do all right in a 29 x 32.5 x 65 oven?
35.5 cubic foot
Re: Oven elements
Originally posted by X-LinkOk so I removed the elements from my old kitchen oven and the regular element is 3000 watts and the broiler is 2900 watts. So 5900 watts total
35.5 cubic foot
Yes you will be fine providing you have a good insulated shell , our 3x3x6 oven has 5400watts and gets to temp within 10-15 minutes , so you should be ok
Re: Oven elements
[/quote]Yes you will be fine providing you have a good insulated shell , our 3x3x6 oven has 5400watts and gets to temp within 10-15 minutes , so you should be ok[/quote]
Good to know, I am toying with the idea of building a 3x3x6 or a 4x4x6. Figure if I can't do coating now might as well build a bigger oven. Makes sense to me anyway
Re: Oven elements
Originally posted by tedsfabOriginally posted by X-LinkOk so I removed the elements from my old kitchen oven and the regular element is 3000 watts and the broiler is 2900 watts. So 5900 watts total
35.5 cubic foot
Thanks Ted!
I'll have 4 inches of Mineral wool so I should be good.
