Technical Data Sheet - Standard
  • Technical Data Sheet - Standard
    Name: RAL 7016 GEHL GRAY Type: Glycouril Polyester
    POWDER PROPERTIES
    ASTM D5965-96, C Specific Gravity 1.48 + 0.05
    Theoretical Coverage 130 sq.ft./lb/mil
    ASTM D3451-92,13 Mass Loss During Cure < 2%
    Maximum Storage Temp. 75?F
    COATING PROPERTIES
    ASTM D523-89 Gloss at 60?F 70-80%
    DPC TM 10.219 PCI Powder Smoothness n/a
    ASTM D2454-95 Overbake Resistance Time 100%
    ASTM D3363-92a Pencil Hardness F
    ASTM D2794-93 Dir/Rev Impact, Gardner 120/40 in/lbs
    ASTM D3359-97 Adhesion/Cross Hatch 5B Pass
    ASTM D522-93a Flexibility, Mandrel ¼ in. dia., no fracture
    ASTM B117-97 Salt Spray 1,000 hrs
    APPLICATION
    Electrostatic Spray, Cold
    Substrate: 0.032 in. CRS
    Pretreatment: Bonderite 1000, Parcelone 60
    Cure Schedule - 10 Minutes @ 400?F @ Part Metal Temperature
    FilmThickness: 2.0-3.0 Mils
    This product is designed to penetrate Faraday cage areas with good coverage using standard corona discharge guns
    Prepared 4/29/2008
    Re: Technical Data Sheet - Standard
    Please Note: Application
    Electrostatic Spray:Cold
    Pretreament: Akaline Cleaner, rinse, Phosphate
      This is a poly-condesation crosslinking reaction, like in polyester/HAA (Primid) systems.
      Max. Filmthickness is very important, otheriwise you will get pinholes.
      The condesation product is Methanol -> proper venting of oven is a must.
      A little additional information for your viewing pleasure
