PRIMERS- when and why
  • PRIMERS- when and why
    with 5 primers being offered when would you use one and which one for what job? i have used the kl primer in the past to fill in areas or when a customer tells me to "go heavy" on the coating but not the others.
    Re: PRIMERS- when and why
    Primers are specific to the application...which primer do you have a question about ?
      well, i guess all of them. like the red oxide primer. when would it be necessary to use it? zinc rich primer over steel parts subject to outdoor use... etc.
        thanks. it's in my notebook now. (hmmm... where did i put that notebook)
          when and why ?
          Whenever I don't want to do the job twice.
            Also keep in mind that the Red Oxide Primer can be applied up to 20 mils and is also easily sandable.
              I do alot of cast aluminum parts and usually always use KL primer. Would it be better to use the red oxide?
                20mils? No thats thick. I guess you could sand and smotth out just about anything. Nice!!
