Most durable powder?
  • Most durable powder?
    OK so I need to do some underbody coatings. Brackets and hangers to start, then eventually subframes and such. I am looking for the toughest possible powder(s) Any suggestions?
    So far I am thinking Red Oxide primer with Black Carbide. Good combo? bad? other?
    Thanks for the help
    Re: Most durable powder?
    Welcome augiedogie1.
      The Black Carbide Texture has a nice impact restistance and is a high performance powder, so if you are looking for a tough texture - she will do the trick
      Welcome
        Have you ever used any nylon powder coatings?
        If not you may want to try them.
        Use a nylon primer as a base coat first.
        Born2drive
          Welcome
          Yes, I read that it has nice impact restiance, that was what drew me to it. I was just wondering if I could up the duribility, with a primer. I would rather do just the one coat but if I can I can make it better i'll go two.
          Oh and not that it should matter but im using the eastwood hobbby gun.
            The Red Oxide primer is a great primer and should also work well for your application.
              So will the primer give any added durabilty? I would prefer a one step approch, but I want to make thes as tough as possible.
              and no I don't need a textured coat, just read that carbide had good impact resistance.
                Durability covers many factors, if you are looking for impact resistance then the SD Wet Black has a 4H Pencil Hardness and an impact resitance direct and indirect 140-160 but only if you go with the recommended mil thickness ..
                  I was looking at the SD black trying to figure out what would work. I feel guilty about using it for under body parts, it looks so nice. How forgiving is it to work with? So far my only experience is with a handfull of Eastoods colors.
                    I ordered the black carbide, the black 60% super durable and the red oxide primer. Now a week for shipping GA to Seattle
                      Wow shipping was fast!
                      OK so i'm going to due the parts with black carbide and primer.
                      Whats the best way to do this combo?
                        Yep PBTP does not mess around with shipping unless UPS does not like NIC placed the order Fri morning on line they got to it on Mon and I think shipped Tues and I received it the next Tues Next time I have to order from them you bet I will call I have received powder from them in 3 or 4 days not 7+ days.
                          Starting a new post on the primer
