harley hub help
  • harley hub help
    o.k., i get 2 harley hubs . one is steel and one is aluminum. the aluminum one"s chrome is flakeing off so i blasted it and gave it a coat of KL primer. i shot the aluminum one and it came out looking good. i shot the steel one that was in good condition and the color is MUCH DARKER than the aluminum one . what the heck happened! both cured in the same oven but not with each other. could the steel one heat up too much to cause it to get dark? color is red and the finish looks the same but are way off in color to each other.
    Re: harley hub help
    it's called blood red from CC. i have used it before. yes both hubs were chromed but the aluminum one was crappy and flakeing so i blasted and gave a coat of primer. if the part was too close to the element will it turn it darker? the color is uniforme just much darker.
      Re: harley hub help
      It's more likely that the color difference is the result of one being shot over a basecoat and the other not. With two different substrates, it's more important to have an identical base in order to get consistant color.
        Re: harley hub help
        O.K. now listen too this (and i have a witness). after i saw that this happened i came in to post this and have some lunch. i went back to reshoot it and the color CHANGED to what it was supposed to be!!! my daughters boyfriend came looking for me and noticed the same thing. he even said "i thought you are going to shoot them the same color?" we both saw the darker color on the still hot part. what the heck happened?
          Re: harley hub help
          I get the same problem w/steel everything comes out darker.. Tried multiple times on some steel bar-ends on a busa to come out the same as the aluminum foot pegs.. It just wont happen.. My theory is steel is just a darker metal and wont produce the same color as aluminum will, at least w/Red colors anyhow...
            Re: harley hub help
            red yellow blue, all very transparent.
            if you pay attention most all powder colors change after they cool
              Re: harley hub help
              . Another one is the pac car black semi-gloss. When you pull a part from the oven you could swear you just shot a gloss black, but as the part cools it flattens out.
              You will also notice this with PBTP's 40% gloss black... it looks a lot like bumper black fresh out of the oven. Give it 15-20 minutes and it looks satin.
