ok...Im gonna jump on the aluminum beer bottle band wagon! For those of you doing them...how are you prepping them?
Aluminum bottles.....
Re: Aluminum bottles.....
Chemical strip (aircraft or cybersolve) that removes about 90% of the stuff on there. Then just blast them like any other part.
I got off to a slow start with these and was only able to do about 1 every 10 minutes. Now I can get a dozen of them done in that amount of time. Just do a few at a time and leave them ready to shoot, that way every time you shoot a new color you can just grab one.
Most of the time the bottle doesnt even need blasting , when stripped they have a brushed aluminum finish and can be shot just like that. I doubt the adhesion issue will be of concern on an item that sits on a shelf for display. I dip my bottles in the B17 for 30secs to a minute, then rinse and it ready to coat. Here is a Miller Chill bottle straight out of the stripper and rinse.
I just use a hanging wire with a bend in it about 3/4"at about a 45 degree angle, you may need to play with the length and angle til you get it right. Then just feed the wire in til it clears the neck and then pull it straight out til it wedges itself in the neck, then just hang it and shoot.
B17 is a chemical stripper from Benco Chemicals, you can order it from CC or direct from Benco, CC just sends the order to Benco and Benco delivers it to you, no upcharge on CCs end. It is very cheap, about $125 shipped for 5 gallons. $65 for the B17, $25 hazmat fee and about $35 shipping depending on where you are from.Its around $325 for 30 gallons and they will truck it to you for free with no hazmat fee, bringing the price down even more per gallon. This stuff is very hazardous if you dont play by the rules ,but nothing ,and I mean NOTHING will strip faster or work better. Unlike Desolve 1012 where you have to remove(strain) the old p/c out or it keeps working til the solvent is dead, you can just leave the stripped p/c in the bucket and it doesn't do anything. You need neoprene gloves and you dont want to breathe it. It will strip a Bud bottle in 30 seconds and most other parts with p/c on them in 10 minutes.
Originally posted by o1racing03I just use a hanging wire with a bend in it about 3/4"at about a 45 degree angle, you may need to play with the length and angle til you get it right. Then just feed the wire in til it clears the neck and then pull it straight out til it wedges itself in the neck, then just hang it and shoot.
Originally posted by pchotrodderOriginally posted by o1racing03I just use a hanging wire with a bend in it about 3/4"at about a 45 degree angle, you may need to play with the length and angle til you get it right. Then just feed the wire in til it clears the neck and then pull it straight out til it wedges itself in the neck, then just hang it and shoot.
I'm with ya. I really want something that works fast and all. But this stuff is far to dangerous no matter how you use it.
Im using cybersolve for now. Even that stuff makes me cough, I have to wear a respirator when working with it. It makes my eyes burn like a mofo too.
**Note to selfdon't breathe while leaning into the 55 gallon barrel.
You only have to do that once.
Originally posted by Brune292Anyone using anything cheaper or different to strip the bottles with??
