Well been coating for a while and it seems like no matter what i do i still get small amounts of orange peel. I just wanted to know common problems the cause it and ways to fix it, maybe people can post their experiences .
orange peel problems and ways to fix em?
Re: orange peel problems and ways to fix em?
Just keep in mind that depending on the powder and the shape of the substrate (large flat surfaces are the worst for showing it), almost all powders will show some very slight orange peel. Good news is, you can colorsand and buff just like automotive paint with the right equipment and compounds. The search should give you lots of suggestions based on the type of peel you're seeing. I would venture to say that the biggest reason for orange peel, particularly for those just starting out, is applying the powder too heavy.
Best of luck.Dan
Originally posted by wiseguyzJust keep in mind that depending on the powder and the shape of the substrate (large flat surfaces are the worst for showing it), almost all powders will show some very slight orange peel. Good news is, you can colorsand and buff just like automotive paint with the right equipment and compounds. The search should give you lots of suggestions based on the type of peel you're seeing. I would venture to say that the biggest reason for orange peel, particularly for those just starting out, is applying the powder too heavy.
I just bought a buffer and the 3 different 3M pads for compounding, buffing, and polishing. Now I need to find the right compounds. I heard the Liquid Ice 3-step system works very well, but I haven't bought any compounds yet, so any suggestions are welcome. Someone at the rodeo suggested a "B4" compound, but not sure what brand that is.Dan
Originally posted by wiseguyzI just bought a buffer and the 3 different 3M pads for compounding, buffing, and polishing. Now I need to find the right compounds. I heard the Liquid Ice 3-step system works very well, but I haven't bought any compounds yet, so any suggestions are welcome. Someone at the rodeo suggested a "B4" compound, but not sure what brand that is.
http://solutions.3m.com/wps/portal/3M/e ... RKGRPJV4gl
Tech support at powder by the pound had a good suggestion for the orange peels. He said to preheat the oven to cure temp, coat the part, and after putting the part in the oven turn it off for 10 min. Then turn the oven back on and cure. This was to give the powder more time to flow.
3M has a 3 step kit that has the polishes and the pads numbered 1,2,3 and color coded so you cant go wrong, runs about $89-$110. I am working with my friend in the industrial supply business right now trying to get a rice break I can pass on to members here from his 3M supplier. I tried this kit at my friends street rod shop and after sanding with 1500, I was amazed at how easy it was to get a mirror finish with this stuff. Key is an absolute clean environment as any dirt, grit, debris will cause swirl marks requiring more sanding.
