What do you guys get to do ATV wheels out there. Just looking do do mirror black.
ATV wheels
Re: ATV wheels
single piece spun aluminum. The front lip and rear lip is the hardest part the its too tight of an area to draw powder into. I cheat a little and use spray paint for the area just to get it covered, then coat the whole thing. also when you blast them you will have to thoroughly clean that lip out if not sand or glass or whatever your media is will come back out of it. so watch out for it. the lip im referrin to is smaller then 1/2 the thickness of a razor blade.
Re: ATV wheels
They can be a p.i.t.a. for sure. Those lips also hold grease and crud (and D-Zolve) that can run out and mess things up for you during cure as well.Dan
Re: ATV wheels
I've done several sets and have been fortunate in that I've not had to strip paint/powder off of any. I'm w/ rbroker on the picks, scrape as much of the dried dirt and mud out and then blow w/ compressed air. I then just give them a good soap and water bath, blow dry, wipe with Prep-all let dry and coat.
