did any one ever fig.out how that marble effect was done??no one on any other fourms have talked about it last post around march have had some luck using a damp seasponge but the swirls ect cant fig.that out yet any one else try this??
marble effect?
Re: marble effect?
Originally posted by BeeBobThat'll give you more of a "wrinkled" look and not as even and smooth looking. This marble effect seems to be some sort of a liquid swirling around for the top coat. Like dripping some paint in a big bucket and stirring it around.
Re: marble effect?
yea like that look on the bows its dipped somehow just prob a mix of l2p and maybe water or something i dont want to waste 100s on trying to fig it out but im just curious its a cool look for some stuff and who knows maybe come up with diff.loooks and dif styles i like to experiment.just $$$ is a lil tight just looking for more info ect..
Re: marble effect?
I have heard of people dipping it in a stripper or spraying on a stripper. Not sure how this would work with curing etc.
Have you ever seen D-Zolve 1012 when you are stripping? It comes off like liquid. I bet you could spray it on and use some saran wrap if needed then maybe let dry and re cure?
Not sure. But its a cheap way out. Maybe even paint thinner would work. Once again I do not know if it will kill the properties of powder coating. I wonder if it just puts it in a liquid state and then air drys and you can re cure it?
Worth a shot. Afterwards just do an MEK test to see if it fully cured.
Re: marble effect?
Originally posted by SWITCH420TRIED LAC.THINNER NOT SO GOOD MEK WORKS OK HAVE NOT TRIED THAT STRIPPER YET OR STEEL WOOL THANKS FOR THE INFO
MEK I figured would dry too fast for you to even mess with it.
