Here we go boys ! what different technique's do you use for applying these products ?
Techniques for Candies
Re: Techniques for Candies
ALRIGHTY THEN,here we go.
I had lots of issues with all type and brands of candies.burning,drowling,you name it i had it.
"UNTIL I MET PBTP"THANKS TO TODD @TNC, AND ALSO DONALD @PBTP......
I HAVE BEEN CURING MY CANDIES @LIKE 350-375 FOR A LITTLE BIT LONGER PERIOD OF A TIME.
ALSO I'VE NOTICED THAT KEEPING AWAY FROM THE HEATER ELEMENTS HELPS TOO.
I SOME TIMES USE A METAL DEFLECTOR TO KEEP DIRECT HEAT TO MY CANDIES AND THEY TURN OUT SWEET.NOW THIS MAY VERY FOR OVEN MANUFACTORS FOR THE WAY THEY ARE BUILT....
,BUT THIS IS WHAT WORKS FOR ME.........
I have coated some fresh chromed parts in candy purple and they came out great. I did notice that if I cured the powder according to the enclosed cure schedule, I would get some orange peel. I learned to fix this by bringing the part up to about 250 and let the powder flow out until it was as smooth as glass, then i would cure as recommended. Works well!
Originally posted by Slightly WarpedI have coated some fresh chromed parts in candy purple and they came out great. I did notice that if I cured the powder according to the enclosed cure schedule, I would get some orange peel. I learned to fix this by bringing the part up to about 250 and let the powder flow out until it was as smooth as glass, then i would cure as recommended. Works well!
The best way to cure powder is by PMT ( Part Metal Temperature). Here is a link that might be worth reading viewtopic.php?f=5&t=658
I would still rather overcure than undercure. On heavier parts like frames, your PMT is rarely reached by the time the powder flows out. In my experience at least, PMT takes well beyond flowout in most cases.Dan
For a chrome powder base, I coat the powder chrome at 45-50 kv's, that way when applying the candy, I can use lower kv's, around 25-35. As for any type of silver base, the base coat kv's are around 50-75 kv's but that also depends on how much metallic is in the powder and what shape the part is. The candy coat for silver base, I'll coat at around 25-50 kv's. And for a polished aluminum base or any metal base, I'll coat with a candy at 45-75 kv's. As for applying the candy coating, I only make one pass, with 25% over lap. Depending on the candy color and who makes it, you can add a bit more where needed. I always over cure by 5 minutes. And to test to see if cured, I'll hit the cured candy coat with a wooden mallet (if possible), that way if it cracks, I know it isn't cured. I also use those settings for transparents. As for the air pressure and powder flow, can't really say, as I go by what I see coming from the gun tip. And if the equipment will allow it, I'll switch the charge. ( Nordson SureCoat's: recoat mode)
