Welcome! Some great news: We have recently upgraded our forum. In addition to the mobile website version, you can now download Android and Apple Apps for a truly premium experience. You owe it to yourself to click on the link above and download your app now. Also, we have improved our security. Some registrants were removed in this process, but rest assured, all posts were retained. Our apologies in advance if you find yourself needing to re-register, and we thank you for your continued support as we seek to improve your experience.
If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Thanks for the info King Back when we started out, we had the Caswell Super Stripper that we used on a stock Evo VC and that worked fine, just didn't do very much. So going forward, I'll probably use that for the Evo VCs to be safe.
The passivation range of Magnesium is at pH 10.5 and greater, which means that when trying to remove a coating from this substrate a high ph stripper is required..
