Originally posted by polert
What are the bottles some people have used as tested panels
Re: What are the bottles some people have used as tested panels
Originally posted by GONGCHUANAre you blasting these bottles before you coat them or are you stripping them in any way? Are they thick enough to go through a blast?
Thanks,
Mike
Thanks,
Mike
Just wanted to post this, incase someone is still having issues with the letters bleeding through. This is a bud light can soaking in spray gun cleaner, as you can see it takes the label right off and all I do is wash the bottle before I powdercoat it. I found this stuff works great on taking powder off as well. I do not have to blast whatsoever.
hope this helps someone.
Originally posted by CPC-2Originally posted by GONGCHUANAre you blasting these bottles before you coat them or are you stripping them in any way? Are they thick enough to go through a blast?
Thanks,
Mike
That is a ZEP formula, I dont have any id number, Ive got 10 gallons of it and it works great. I will get the number if anyone is interested though, just dont have it in front of me tonight. This stuff is nasty though, if you so much as put your arm down in the pot/ or whatever its in your whole arm starts heating up. Badddd Stuffff, but it sure does the job. Yes it comes off in sheets instead of melting the coating.
Only reason I tried this stuff at all is cause my dad gets a heck of a discount at his job on it. Found out it worked, so good for me. Ill at least pass on the full name and any #s on the stuff as soon as I can get to them. (probly a day or so before I get back over to my dad's)
Originally posted by GONGCHUANThat is a ZEP formula, I dont have any id number, Ive got 10 gallons of it and it works great. I will get the number if anyone is interested though, just dont have it in front of me tonight. This stuff is nasty though, if you so much as put your arm down in the pot/ or whatever its in your whole arm starts heating up. Badddd Stuffff, but it sure does the job. Yes it comes off in sheets instead of melting the coating.
Whats D-solve dude?
Harley[/quote]
D-zolve 1012 is a stripper made by Solventkleen. It actually dissolves the powder vs the powder releasing in pieces like you see in the above photo.. It works well but needs to be filtered or it continues to work on the sludge
that settles to bottom and gets weaker.[/quote]
Thanks HD.
The above stuff doesn't PBTP have some that works similar to it?
