HOW MUCH PSI TO THE CHINA GUN?
  • HOW MUCH PSI TO THE CHINA GUN?
    how much psi should there be connected to the control box on the china gun?
    Re: HOW MUCH PSI TO THE CHINA GUN?
    Around 20lbs, this may need to be adjusted depending on what is being coated and/or what powder you might be using. I would also wiat to hear from some of our customers on what they think.
      15 TO 18 FOR COLORS AND 5 TO 8 FOR CLEARS AND CANDIES SEEMS TO WORK BEST FOR ME AT THIS POINT,STILL EXPEREMENTING
        A LITTLE BIRDIE TOLD ME THAT YOU MIX ALOT OF PRODUCTS TOGETHER....HOW DOES THIS EFFECT YOUR SPRAYING PROCESS ?
          so from my compressor to my air regulator/filter i should drop the pressure down to 18-20 psi and then hook up the air line to the BACK of the control box? then the front of the control box has 2 "adjustment of powder feeding air pressure" control knobs. one has a orange label and the other has a blue label i'm assumeing the blue adjustment is for the gun itself and the other is for the air gun they supply to blow off the powder gun when cleaning.
            Dear customers,
            Thanks for your purchasing Electrostatic cup gun manufactured by our company. Before using the equipment for the first time, please carefully read this Operating Manual, which will help you use the equipment successfully.
            If any problem happens in your use, please contact with us in time. We will surely satisfy your requests and provide you with perfect after-sale service.
            Catalogue
            I. Main Technical Parameters 2
            II. Sketch Map of Obverse Structure 2
            III. Sketch Map of Reverse Structure 3
            IV. Sketch Map of Spray Gun 4
            V. Operating Instruction 4
            VI. Attentions 5
            VII. Frequent Failures 6
            ? 1. Voltage of power supply: 220V-240V AC voltage
            ? 2. Input power: 40W
            ? 3. Output voltage: 0-100KV
            ? 4. Maximum output current: 200uA
            ? 5. Voltage of solenoid valve: DC24V
            Instruction?
            1. Voltage-Adjustment Button Clockwise direction for voltage increase
            2. Voltage Indicator Maximum 100KV
            3. Current Indicator Maximum 200Ua
            4. Powder Feeding Button? “Pull”Clockwise direction for powder volume increased, normal air pressure indicator is 3-4 kg
            5. Powder Blending Button: “Pull”Clockwise direction for powder volume decreased or thinned, normal air pressure indicator is 0.3 kg
            6. Atomization Button: “Pull” Clockwise direction for powder atomization, normal indicator is 0.1 kg
            Aroung 20 PSI or Less
            V?Operating Instruction
            ? 1. Connect all the connecting lines and air tubes according to the above sketch map
            ? 2. Turn on switch of power supply (lighting indicator is on)
            ? 3. Press the switch of spray gun to adjust voltage required (set by individual,
            voltagerecommended is 60KV-80KV)
            ? 4. Powder is placed into powder feeding barrel
            ? 5. Press the switch of spray gun and adjust to high-voltage. Start work if the powder is sprayed.
            VI. Attentions?
            ? 1. Well connected with the ground
            Grounding line is attached with the equipment and must be connected with the spray booth, which is to be connected with special clean ground. Workpieces, hanging articles and support must be connected with grounding line to prevent grounding failure from making discharge sound.
            ? 2. Air source must be clean
            All compressed air must be kept tidy and dry, and has no oil or water. It is recommended that the customer use frozen and dried air sources. If the customer uses general oil-water separator, the oil and water must be regularly discharged in case that the coating ratio will be influenced by water accumulation in air box of powder barrel, solenoid valve and air tubes or too much humidity.
            ? 3. Prevention of spray powder
            If abnormal powder spray (i.e. bigger or smaller from time to time) happens to new equipment, generally that’s because powder feeding and lending air pressures are not properly adjusted. Powder spray increases as powder feeding air pressure increases. Adjust the powder blending air pressure to a higher level to ensure that powder spray is in uniform.
            ? 4. Tidy up the powder in time Powder pump and spray gun should be blown and tidied up with compressed air after they are used for some time.
            ? 5. Adjust properly
            Pressure regulating valves own locking device, in which “Push” means “off”, “Pull” means “on”. The buttons of various regulating valves should be adjusted to proper position (as is to be indicated by satisfactory powder spray).Check the following conditions if the air pressure is not enough.
            (1) Whether the air pressure in compressor is more than 6kg;
            (2) Whether there is a leakage in the air tubes;
            (3) Whether pressure regulating valves are in good condition. Generally the pressure regulating valves are easy to adjust, anticlockwise direction to the end (off) or clockwise direction to the end (maximum). Do not regulate them violently. If the pressure can’t be adjusted to a higher level, the equipment will not be used until relevant solutions are found and failures are repaired.
              THE MORE METALIC/PEARL IN THE POWDER,I LEAN TOWARDS THE HIGH SIDE.CLEARS AND CANDIES,TOWARD THE LOWER,KEEPING THE KV AS LOW AS POSSIBLE.
                PICS PICS PICS PICS PICS PICS PICS PICS PICS PICS ... okay so now you know what I must have :P
                  OK OK OK OK
                    AWESOME, my little pig tummy says MORE MORE
                      THIS FLIPS GREEN TO GOLD TOP TO BOTTOM AND BLUE TO PURPLE LEFT TO RIGHT
