Do you guys normally clearcoat everything, no matter what color? Does it make it more durable or just make it shine a little more? I sprayed some on a piece that I did in Silver vein, turned out nice. Just wondering when a guy needs to use it and not use it. I also tried some PC liquiguard because I was having trouble with orange peel, and that also took care of the problem I was having. Thanks
Clearcoating
Re: Clearcoating
Wise is correct, the particle size or micron is smaller in a clear coat. The additive is heavier which allows the metal flake additive to lay down underneath the coating. This doesn’t apply if you add too much metal flake though, by adding to much the flake starts to build up on each other and will stick through the surface.
Re: Clearcoating
Originally posted by powderbuyWise is correct, the particle size or micron is smaller in a clear coat. The additive is heavier which allows the metal flake additive to lay down underneath the coating. This doesn’t apply if you add too much metal flake though, by adding to much the flake starts to build up on each other and will stick through the surface.
Ok thanks! But any other kind of powder that has metallic in it, i.e. silver sparkle, or other powders under your "metallic" category, should be cleared right?
Re: Clearcoating
Yes, unless they are the FlipFlops! Mirror Silver Sparkle does not require a clearcoat as well (per the manufacturer) but this means that there is very little metallic in the product and the metallic has been encapsulated by the polyester. You can always call or email for more specific information.
