Got an HD frame in from @ 1963ish I'll be doing in PBTP bike black. Looking at pic 1, Any idea if this hard black "plastic"? bushing piece will melt BEFORE I put it in the oven only to find a puddle on the floor!? Pic 2, This is the only ID #/data plate we could find. Hopefully this will not have to be riveted back on the frame! Thanks
I would be willing to guess that the bushing will not take the heat. I would let the customer make the decision and explain the possibility it will most likely melt. On the plates I will usually remove them fro my customers but I let them decide how to put them back on. If you drill out the rivets and place the frame in the oven to about 200-225 the plate should peel right off without damage use the tip of an xacto knife to get it started.
It looks as though you could tap that plastic bushing out with a deep wall socket and a hammer. Although if it's 40yrs old that might be easier said than done.
The bushing is it in a bottom hole.( a hole that dead ends ) It doesn't look like it goes all the way through? I would go with AutoCycle and talk to the customer. If it's a bottom hole you can't press it out. If it does go through you might destroy it getting it out after all this time.
A ball joint press would be the easiest.
