Hello, I'm looking to fix some hot spots in my oven. I want to fit larger items in the oven but when I get within 6-8 inches of the burners the powder gets cloudy (too hot I read somewhere) Any ideas on how to even out temp closer to the elements? I read that ceramic tiles would work, but are all tiles created equal? Or go buy the cheap drops at Home Depot. And would I be able to get an inch closer or would I be able to put a part real close to the tile? That would add about 40% addtional capacity to my oven. Quite substantial.
Here's the oven, it was a double and I cut out the center section. I had it up right but there was a 80 degree temp difference from the top to the bottom, so I turned it on it side.... Problem solved for the most part.
