Will an EGR valve take the heat?? (pic inside)
  • Will an EGR valve take the heat?? (pic inside)
    My dad wants me to powder coat the EGR valve off his Lighting cause he already painted it once with high temp and it flaked off. I'm sure the "mushroom" on top has some kind of rubber diaphragm inside or something - anybody know if it will take the heat?
    Re: Will an EGR valve take the heat?? (pic inside)
    Get the motor hot and temp that with your IR GUN. I am curious to see what heat it gives off.
      we always take em apart
        Yeah, that's what I told him to do, but he only takes it out every once in a while and that valve doesn't open at idle. So we're gonna check it the next time he takes it out, who know when that could be though, lol.
          How do you take it apart? The top half of that "mushroom" is crimped onto the bottom half...
            there is a snap ring on tne bottom of the cap ! when you take that out it's insides pretty much fall out!!!!
              Oh didn't catch all that figured it was like a mustangs
                Yeah, there's no snap ring anywhere on it, and I don't think you could take it apart without ruining it.
                  hit mattew up about some low temp powder
                    My dad had the L out today and got it good and hot and I took the temp and it was about 200*. So you think it would take the heat? What temp does low-temp powder cure at, 325*?
                      Some low temps are in the 200 range (High to mid).
                        I found a junk spare EGR I had laying around for an old t-bird super coupe and tore it apart. The diaphragm inside it is high temp silicone rubber, which I tested in the oven at 400 degrees and it was perfectly fine.
                        So for future reference I would be willing to bet that it is an industry standard that all these have the high temp innards and can take the heat.
