Despite the physical conditions (faraday cage),it is possible to achieve a minimum coating thickness in the corners. With poor penetration
procedures penetration depth is very limited.
Extreme film thickness variations are noticeable....
Here are some possible causes
1. Feed air too high - change or lower pressure
2. Air speed too high - adjust equipment controls
2. Powder flow too high - adjust equipment controls to suit the part
3. Not enough powder flow- adjust/optimise equipment parameters
4. Unsuitable nozzle - Utilize flat spray nozzle or deflector
5. Insufficient charging of powder - adjust voltage
6. Voltage too high - Adjust/reduce voltage
7. Faraday cage area due to electrical field - reduce voltage
8. Insufficient grounding - use clean hooks, test transfer resistance
9. Powder spray too wide - use different nozzle or deflector
10. Distance from gun to part is to big or small - increase or decrease distance
