Weather/humidity is definitely a factor with the Back ionization. Here is how the problem can be virtually eliminated. turn the kv all the way down on the controller and increase the air/powder flow. Start spraying the part and slowly increase kv until you begin to get attraction on the part. Now spray the part in a quick motion across the part if you have some areas that still dont want to attract try pulsing the trigger and putting the powder onto that area a little at a time until it covers. Now you will waste more powder than normal when you are having this problem. This will mainly happen on second coats and its basically like you are doubling the kv that is charging the powder when the humidity is high.
We just worked through this yesterday and I was having the same problem with both my gema and the king coat gun. The back ionization was so bad that you could stop spraying powder stand back and watch the pin holes just appear. Made these adjustments and layed down three coats cold, and then base coat / topcoat on a test panel cold.
