Ok, so we are new to PC'ing (hobby set up), and we are having an issue with Mirror White on a valve cover. We prep'd the cover by blasting, out-gassing, and then using acetone to clean before coating. The powder / finish looks great, except there are a few spots where red has seeped through the white. The valve cover was originally painted red, but after blasting there were absolutely no signs of red on the surface before we coated it (we checked and double checked as this was the second one and we had the same problem with the first one).
So, I have a couple questions......
(1)Is there something else we should be doing for prep?
(2)Would a primer stop this from happening?
(3)Is this just an issue with light colors, or would it happen with darker (gold) colors too?
(4)Best product to use to strip the finish off the first one?
Any advice is appreciated!
Thanks!
Thanks!
