I've decided that building a bigger oven, although more expensive, is a higher priority at this point than a bigger booth... so I'm going for it.
To be honest, I have yet to REALLY outgrow my 30" oven. I haven't turned down any big jobs (financially) because of oven limitations, but I want to be ready for the near future. I'm also building this in my head with a few notepad sketches, so if any one my numbers are wrong, please feel free to correct me.
I've always been told to build the biggest oven I can afford and think I will need. My space limitations for width and depth are 6x6 feet and I would not like to go any taller than 6 feet. So technically the biggest oven I can build is a 6x6x6. However, the sheet metal panels I can find locally are 10x4 feet. If I make a 6' tall oven then my other two sides have a max size of 4'.
A 6x4x4 oven seems to be a good size. However, it is not the best 'bang for the buck'. I can maximize my sheet metal usage by cutting by the 10x4 panels in half and making 5x4 panels for each side. I can also get 4x3 panels for a decent price... so basically I've ended up with a 5x4x3 oven.
Inside dimensions: 72h x 44.38w x 32.38d
At this point I'm mostly concerned with building the actual box. So I'm focused on sheet metal and insulation. I've started purchasing the materials for the phase of the build and started researching the electronics behind it.
What is the different between the square elements found inside the oven and the round elements on the stove? This may sound like a stupid question and I'm sure there is a simple answer to it, so I would like to know. Are they basically the same thing but less powerful? Can more of these smaller round elements be used in place of fewer big square elements?
Building a 5x4x3 oven instead of a 6x4x4 oven will cost 33% less in sheet metal. It will also be a considerable amount in metal studs that I have not calculated yet. It will also fit better within the space I have assigned to the oven and probably cost less to operate. I know these are good enough reasons for me, what do you guys think?
