Cybersolv ?
  • Cybersolv ?
    I am in the process of building me stripper :P tank. I would like to hear from some of you that use cybersolv this what I'm going to use. Where I locate it for instance will be determined mostly by fumes. Where does everyone place thiers? Wtih a lid shut is it fumey should I install a exhaust fan (which I'm already thinking about) above the tank? This way when it's uncovered to strip something the fan can remove the fumes. Duke already pointed out about aeration. Any of thoughts or points?
    Re: Cybersolv ?
    If you plan to heat it definitely go with an exhaust hood!
      Re: Cybersolv ?
      Thanks Jason. yes I plan on putting in a heater. Just haven't decided on what heater to use yet.
        Re: Cybersolv ?
        I look forward to seeing pictures of this setup Harley. I've been saving a corner of my shop with plans of eventually building something similar, so some pictures would really help my planning. Good luck with the build...
          Re: Cybersolv ?
          Juan]I look forward to seeing pictures of this setup Harley. I've been saving a corner of my shop with plans of eventually building something similar, so some pictures would really help my planning. Good luck with the build...
