I think mine drops 3-5 PSI from off to flowing air. It kinda irks me too, when you wana set for a PSI, then its less when trigger is pulled. But really, every time I fill the hopper, I spray into my exhaust filter and waste a bit of powder, adjust flow for good powder delivery, not what the gauges say
For the guy's with pro guns
Re: For the guy's with pro guns
i will have to check the pressure drop tomorow but you guy seem to run lots of inlet air to your units .
when the salesman instaled tge wagner he had about 90 lbs in , but i have a hard time with that because when i try doing adjustments to get only a small cloud to do parts like heads and cyl i get problems now i run abut 60 pounds and it s ok
my Gema the analog one (pg1) i run at around 40 lbs but i usually use that one for special stuff like fades or other fancy stuff
