Black wrinkle texture options...
  • Black wrinkle texture options...
    Going through the catalog looking for some black wrinkle for a customer. I'm basically looking for the same texture as the Red Wrinkle. I'm not sure how most of these look and there are not enough pictures, any suggestions?
    Thanks!
    Re: Black wrinkle texture options...
    This is the same texture as the wrinkle red:
    viewtopic.php?f=4&t=1007
      So you basically use the red wrinkle as a base coat and then went over it with black? If so, what black did you go with?
      Thanks!
        Yes its the S&S wrinkle black from PBTP.
          Good eye, Harleydad!
            I use Dupont Wrinkle Black from a customer, he supplies it for me Its appears to be the same as the wrinkle red from the pics. Although, I havnt used the W red yet
